406 ABS/ESP fault
PC2CV
x 7
406 ABS/ESP fault
Unread post by PC2CV »
My 406 V6 (2001 Multiplex Estate)when started throws up lights/messages for the ABS/ESP system, airbag fault and the power steering is heavy.
I recently replaced the alternator and battery, and what i assume to be the ABS/ESP ecu was unplugged at the time, its all plugged back in now and been inspected a dozen times.
PP2000 is saying the following:
Airbag ecu - remote permanent fault. Vehicle speed information.
Power steering - permanent fault: sensor signal: vehicle speed/(short circuit to positive or circuit open).
Bsi - no communication with abs or esp ecu, vehicle longitudinal acceleration information incorrect value received and vehicle speed information incorrect value received.
ABS or ESP ecu - the ecu has not replied
Engine ECU - remote permanent fault, no communication with the abs or dynamic stability control ecu
Automatic transmission - no communication with abs or esp
On an ESP equipped 406, am I right in saying its ECU is located beside the engine ecu?
