C15 Body Shape
Genial2018
C15 Body Shape
Post by Genial2018 »
Hi Guys, firstly thank you for your help so far it's really appreciated! OK, I have a 2004 1.9 C15 and have the chance of a 1996 C15 for spares will I be able to use any of it if I take it!?
Regards........ Steve
x 2028
Re: C15 Body Shape
Post by GiveMeABreak »
It depends on the component you are referring to and the engine type as the were the XUD7 and DW8B Diesel engines fitted. I suspect body parts will be less of an issue, only the mechanical and electronic parts that may have differences - certainly build numbers will play an important part - but we can check most parts against the VINs or each vehicle at the time you need them - should you decide to purchase it.
There is little in-depth material available on official sources, given the age of the vehicle now.
van ordinaire
Donor 2017
x 240
Re: C15 Body Shape
Post by van ordinaire »
There were 2 major changes: Visa f. indicators & bumper + single rear door - long before '96 e& the DW8 engine Marc's mentioned, somewhere around 2000 when it lost the 2 2CV fuse boxes under the bonnet, in favour of the one you have.
The main differences which don't seem to be age related are Lucas or Bosch fuel pumps and, I think, 3 different suppliers of front brakes.
If I had the space I wouldn't hesitate, all the important C15 parts: doors, bonnet, heater, seats, window winders & wheels are the same.
