Bipper1.4HDI 16v Pin assignment in MAF sensor plug
gustins32
Hello Peugeot gurus,i got a problem with maf sencore,it,s showing all the time p0113 fault code,in scaner,i did replace allready 3 maf sencores starting from cheapest in ebay and finishing with eurocarpart for 95£,so my thinking is something is wrong with wirring ,i did get my peugeot bipper in part exchange,and dose,t know much about cars history,car is peugeot bipper 1.4 ENGINE DIESEL TURBO,engine code is DV4TED,i did test all wires from ecu tu plug,got 4 pins,one got 5v (yelow),Ground (brown),12,13v (blue),and 11,58v (white),Only what i did notice on plug it say pin 1,2,3,4 and in actual maf sencore(eurocarpart 1920GG) i can see 4,3,2,1,so my concern is the wiring is not maching to maf sencore,can somebody give me some wiring diagram for my car,I know pin1 should 5v (wich in this case its not ) pin2 is ground pin 4 is 12v supply,so i am bit confused wich is correct whey maf sencore pin out or my harnes,Or maybe somebody did mess around with repining the plug and did mistake,because check angine light comes on 1 time from 4 starts,and fault code can not be eraset. Thank in advance for any replays.
Reason: Split from the Citroen thread and title altered
- x 6945
Re: Bipper1.4HDI 16v Pin assignment in MAF sensor plug
You have made another duplicate post of this topic (that I have now deleted). Please don't multiple post, people will get round to reading it, but a response may take a while.
Back to your query, post your VIN up here and we may be able to help you.
gustins32
Hi o sorry, no worries vin for peugeot is VF3**************[VIN obfuscated, can be read by forum staff]
