Help. Citroen C5 X7 driver door wiring problem
Martin1980
Unread post by Martin1980 »
I need wiring diagram for driver door. The problem is that I can`t control the left mirror,right speaker and lights on the both front doors not working. Do you know from were I can find wiring diagram for that.
x 1056
Re: Help. Citroen C5 X7 driver door wiring problem
Unread post by wheeler »
You would need provide a VIN for a diagram. You probably wont need it though, I would guess if you pull the rubber boot back that goes into the drivers door you will most likely find a broken wire or 2 in there.
Martin1980
The problem is solved. 2 wires was on the wrong position in the connector.
x 1940
Unread post by Paul-R »
That's curious. It's not normally possible to connect the wrong way round as the electrical connectors are fixed with a plastic plug. Someone must have been messing around before. Top marks for finding it!
Martin1980
Wen I was last summer in Bulgaria,I had a problem with wires and I went to electrical car mechanic. But hi hes connected wrong wires.
