I've seen lots of instructions for how to tune an XUD9 Bosch pump for performance by screwing in the max fuel screw.
To what extent can I make adjustments to improve MPG? Is it worth backing it off some, or is it going to be perfect where it is?
Tuning an XUD9TE for max MPG
- x 1457
Re: Tuning an XUD9TE for max MPG
You would achieve the same thing by putting a block of wood under the accelerator pedal. Turning back the max fuel screw only adjusts how much fuel is injected at maximum throttle.
I doubt that there is much you can do to improve the efficiency of those engines.
OnlinePaul-R
- x 1941
Is an XUD9 or XUD9TE? If it's a turbo engine you could increase the maximum boost pressure and fit a large intercooler. Apart from that I can't think of anything engine specific.
