Hi folks, the suspension on my C5 (03plate) has decided to drop to the lowest setting without any warning, theres no "STOP" sign on the dash, the fluids are ok, it hasnt affected the power steering or brakes, if i put it on high setting it doesnt respond ??
any suggestions ????
thanks in advance Paul
Citroen C5 HDI suspension problem
fatherjack2002
- x 5
1995 Xantia VSX 1.9 TD, RIP
N*ssan Pr*mera . HATING EVERY MILE
1994 Xantia LX 1.9TD, RIP
1997 Xantia desire 2 re-homed
2002 Pugeot 307 HDI (not quite a Xantia, but still French)
- x 5648
Re: Citroen C5 HDI suspension problem
Sorry to hear that Paul. I'd guess that the pump motor has failed or a return valve is stuck open.
There's a fair amount of information here that might point you in the right direction.
Can you hear the pump run when you unlock the car or open a door?
- x 6954
Or the fuse has blown due to the motor overheating; caused by some fluid ingress and mixing with carbon from the brushes.
fatherjack2002
- x 5
Hi folks, pump appears to be working ok, infact the problem appears to have sorted its self out ?????
went to car yesterday and it was sitting at correct height and suspension raises/lowers as it should, must have been a glitch somewhere, anyway thanks for you help on this
Paul
Paul
- x 3295
I wonder if doing a BSi reset might be a good idea? That way you should be able to clear up any glitches. That way (all being well, and not a hidden problem) you can be sure the glitch shouldn't return.
