i have had the car for around 6 weeks now ,but as i was driving today there was a slight hesitation in third gear as i was going up hill from second gear seemed like the turbo was not coming in fast
but been told to check the maf and the connection and to giove it a clean ,or to give the car a run with it disconnected to see if this makes it
better
but also been told it may be the egr
hesitation in power in third gear
johnjohn
Reason: Edited for Content
doctle
- x 225
Re: hesitation in power in third gear
If you unplug the MAF sensor the check engine light will come on and you'll need a reset tool to put it out, best to scan the car for faults
Oh buggle
- x 6954
Agree, you need a proper diagnostic with Peugeot Planet 2000 first, to get some pointers, as it could be air, fuel or emissions related. Given the age, it may well need the manifold air intake / EGR cleaning.
johnjohn
ok will take a look at this today ,was told to unplug and drive the car to see if it makes a differance to it at ,and was told about egr.
Reason: Edited for Content - see my PM!
doctle
- x 225
Sometimes a car will run a bit better with a duff MAF unplugged but it will put on the CEL quickly as well and that needs a diagnostic to clear it. I'm pretty sure that disabling the EGR is illegal in the UK and on this site admins will quickly delete/block mention of anything illegal. Did the hesitation come back or was it a one off?
Oh buggle
- x 6954
Yes it is and our advice is always to clean or replace things like the EGR.
johnjohn
unpluged the electric socket on the maf and give a good spraying with electrical spray and took the car for a quick spin seems a little better but not 100 percent
- x 6954
MAF cleaner would be better and don’t touch the wire.
