Bullet connectors
doctle
x 225
Bullet connectors
Unread post by doctle »
The airbag plug and socket is missing under my 207 drivers seat. They are currently badly taped and I get an occasional airbag warning light. I could solder them but that's very permanent. I quite like bullet connectors would they be suitable? I like to take the front seats out occasionally to clean the sides and rails. Any suggestions welcome, Thanks
this maybe https://www.ebay.co.uk/itm/2-3-4-5-6-Wa ... rC1Ufe5zbw
Oh buggle
x 1751
Re: Bullet connectors
They should do the job fine.
x 1240
Unread post by Peter.N. »
+1
doctle
x 225
What do you guys thing of the little plug and socket in the link?
Oh buggle
x 5674
Molex connector was my first thought before looking at the link.
Less chance of mixing up the wiring and while I have had no personal problems with bulled connectors they do seem to enjoy a lot of criticism.
moizeau
x 429
Unread post by moizeau »
If your asking because you already have them, you can reverse the male / female , and use different diameters to avoid re-connection confusion.
Pete
doctle
x 225
I dont have them yet I was thinking or getting the little plug and sockets they have bullet like connectors
Oh buggle
x 3566
If you only needed 2-way connectors then XT30 or XT60 connectors are very good as the contact areas are a bit more robust. The 3-way version is the MR30.
doctle
x 225
bobins wrote: 09 Mar 2019, 11:07 If you only needed 2-way connectors then XT30 or XT60 connectors are very good as the contact areas are a bit more robust. The 3-way version is the MR30.
There are 5 wires on each side
Oh buggle
