Xantia Turbo CT heater on all the time
peters2718
New User
Unread post by peters2718 »
My 1997 Xantia Turbo CT with climate control has the heater on all the time. Possibly no problem in the UK but definitely a problem here with temperatures pushing 40 C. Could be an actuator problem or a control problem. Does anyone know whether the actuator, which I assume controls a flap which directs air from the heater matrix, is accessible without removing the dash, which I am reluctant to tackle.
x 1438
Re: Xantia Turbo CT heater on all the time
Unread post by xantia_v6 »
If I remember correctly, the heat flap servo is mounted on the left hand side of the box near the firewall, just above carpet level.
I think that one of the mounting screws might be difficult to get a tool onto.
If you can get a Lexia onto the car, you should be able to check the operation of the ECU and the flap motor
