My son has a 208 with a 16 plate. I was hoping he had kerb lights so I could buy him some Peugeot laser lights to shine down. Unfortunately he doesn't have any, so I was wondering if his car would be wired up for some and if I purchased then and cut a new hole, would I be able to wire them up.
Gary.
208 2016 any live wire when door opens
crapday69
- (Donor 2017)
- x 59
TheAutisticStig
Re: 208 2016 any live wire when door opens
Hi, I'm no expert, but you could probably get some speaker cable and run it from the interior light to the door. This would include trying to route the cable out of sight through the rubber seal that the door closes onto. You may need to drill a small hole in the door to run the cable through but shouldn't be too big. Maybe use a grommet.
This is only a suggestion but I hope it helps.
Jake.
Jake.
