Citroen c3 risk of particle filter clogging
Jimbob77
New User
Unread post by Jimbob77 »
Hi
I've had this warning light come up on my dash saying about additive too low and needs topping up I guess this is as blue ? Which I have got from the garage but I cant seam to find the location of the the filler cap I have a Peugeot partner van and it's next to fuel tank I did a search in line but can't locate it any where in my c3 does anyone know where it may be ? Cheers in advance
x 5651
Re: Citroen c3 risk of particle filter clogging
Hi and welcome.
I don't know for certain but there are those here who will but I think you will need Eolys fluid for your C3, not AdBlue.
Filling is more involved unfortunately.
Post your VIN and someone will look up the details of your car and advise on the correct fluid - there are several options and some are incompatible with others.
You will also need access to a diagnostic computer to reset the fluid level.
x 6954
Yes, as Steve says, this is not the AdBlue, it is the Diesel; additive that needs topping up. You will have wither a pouch or a tank and this is located near rear next to the fuel tank. Once we have you VIN we'll be able to confirm what type it is and whether a tank or a soft pouch.
