Need some advice on my Citroen DS 23 pallas
My engine number 0673 009 374
Currently using Weber 28/36 DLEA1
Can I used Weber 28/36 DLEA2
Thank you
Citroen DS 23 pallas Weber Carburetor
Kumar9989
- x 3
Xantia 96 2.0 petrol auto
regnum47
Re: Citroen DS 23 pallas Weber Carburetor
I have run these models (on and off) in various guises since the '70s (but not at present). As this is a Pallas, I would think it would be most likely to have the semi-auto g/box and this has a hydraulically operated lever on the carb which closes down the throttle when changing gear. There were various carbs used during the production run with variations on jet sizes and so on but if the two carbs are apparently identical the only way really will be to 'suck it and see.' I don't think you are likely to find any info in the old manuals giving this sort of detail, but there are some very knowledgeable people in the CCC who may be able to advise.
