10 plate citroen c crosser
daveyboy1
hi I have a c crosser we just changed the abs pump alarms all clear .The only thing is now it seems to have developed a gearbox fault the gear selector lights pdrn all when engaged flicker every 10 seconds or so also the gear display on the dash does the same. and the ride is not good please any ideas ..
- x 1056
Re: 10 plate citroen c crosser
Is the new ABS unit programmed correctly? Correct tyre size programed into it etc?
daveyboy1
hi we kept the same ecu as was told it would not need to be reprogramed .And we just plugged it back up the permanent fault code and alarms all cleared citroen are saying its now a case of going around the mullbury bush to find it and mentioned the wheel sensor.which has come up as a temp fault what do you think .thank you bye the way
