Hi menbers can any one help with information or suggestions.
Our 2003 206 peugeot 2.0 diesel hdi is very sluggish and the fuel is up on mpg ,i have changed all the filters running on good fuel bp/ texaco it has been for dianostics
but nothing showing that would cause the problem only air bag fault.
no power 206 diesel
Subsonicnat
- x 11
Re: no power 206 diesel
My Suggestion mate is to check and clean the Mas flow sensor with carb cleaner,it doesn t take a lot to throw a wobbly,cleaned and replaced one over 10yrs on an old Fronty, was a good car to me really. Had me stumped for a couple of hours,put a meter on the connection from ECU and rev it,if you get differences in voltage,ONLY about 5v MAX. if you get voltage variation,cCLEAN the Air Sensor, if it stll persists,,change it, brought mine out of limp mode as well..
oxy..gen sensors, disconnect them,NO Change, RENEW them..
I didn t have a
reader of any discription, if you dosconnect anything and it does make any diffference,change it.
Worked every time for me and a mates car,He bought a NEW Cat, then came to me.
it was a oxygen sensor packed up £17:00 off the bay,Sorted.
I didn t have a
