Xantia 2.0 hdi ESTATE lights
bill hughes
Unread post by bill hughes »
Hi everyone, here I go again, I need to replace the bulb in the f/o/s fog / driving light on the above car, my Haynes manual tells me how to do it but it's for the saloon Xantia , totally different, I started removing panels on the front end but no way could I get to it, any advice would be much appreciated (apart from dumping it and buying a Morris Minor ) many thanks
Bill
x 1438
Re: Xantia 2.0 hdi ESTATE lights
Unread post by xantia_v6 »
The difference is between the Mk 1 and Mk 2 Xantia. I think the official procedure is to remove the front bumper for access, but I recall reading here that with small hands you can reach down after removal of the indicator light unit. Someone else recommended removal of the headlight.
bill hughes
Xantia v6 thanks for your reply, it's 2000 S2 I tried taking out the headlight, got it loose but that's as far as it would go, something was holding it in but I could'nt see what, I looked at getting it with my hands but you would need hands the size of a baby to get in from underneath, if I have to remove the bumper etc I think I will have to live with it, but thanks anyway.
van ordinaire
(Donor 2017)
x 402
I replaced the n/s one on mine, without TOO much difficulty, from underneath, greatly assisted by an LED worklight providing illumination from above.
The o/s did look impossible (so will take longer) due to even worse access. However, that was before I removed the indicator (prompted by some U-bend footage on adjusting the foglights) & now think that's the answer but won't be put to the test 'til I try to fit the yellow bulbs I bought on a whim - & that will have to wait until I actually see the Xantia in daylight.
Citroens:-
'81 2CV Club :cry:
'05 C15 :!:
others:-
Jeep XJ Cherokees x 3 :?
'96 Cadillac Eldorado
'99 Cadillac STS :|
van ordinaire
(Donor 2017)
x 402
So that time has finally come to pass - &, yes, the impossible does take a bit longer BUT, it's done now; full details lifted from latest post in my blog (saves you, perhaps unwillingly, trawling all through that verbage): " . . . it's a fiddle & a half, but it can be done (even in failing light) - without removing the bumper! f-w-i-w, the trick seems to be, remove from above, i.e. through the indicator hole, then disconnect the 2-pin connector, when you can hold the bulb-holder in one hand & easilly remove the clip with pliers. Replace from above, to the point that bulb enters hole in back of lamp then, from underneath, locate bulb-holder in lamp & twist (i.e. fiddle) to lock, then retrieve the lead from above and get the connector aligned with the terminals on the bulb-holder, although I had to get underneath again to actually push it home & positively locate the wire clip. Access was not actually as bad as I feared, in some ways a bigger problem was never having been able to work out how the bulb-holder locates in the lamp shell, exacerbated in my case, I suspect, by some local damage to shell under the hole. The access issue, I found, was offset by strategically positioned LED work lamps, meaning you can form a clear mental picture of the set-up for when you're, inevitably, working by touch."
Citroens:-
'81 2CV Club :cry:
'05 C15 :!:
others:-
'99 Cadillac STS :|
