wiring diagram Xantia HDI
hanskj
I´m in need of a wiring diagram for my crank, no start xantia HDI 2000
Citroen C5 Tourer 3.0 V6 HDI 240 2009
- x 1342
Re: wiring diagram Xantia HDI
Which engine variant and injection system?
hanskj
hanskj
- x 6956
Post you VIN up here and I may be able to help - there are several variants.
- x 6956
Well spotted Mike, I’ll change it
Title now changed.
Title now changed.
hanskj
Thank You.
I found a diagram in an old thread- viewtopic.php?f=3&t=55821&sid=8118ced2c ... 48a61166b0
Its running again
The problem was the wire going from pin 4 on the double relay to the fuel pump in the tank was broken in the right side wing where runs down behind the bumper.....
Its running again
