Gearbox wiring diagram
Chefslot
(Donor 2026)
x 14
Unread post by Chefslot »
C4 PICASSO ESTATE - LEISURE 2.0 i 16v 143 (EW10A) piloted manual gearbox 6
P0561 ECU + permanent supply open circuit
I've read many of threads with a wire in the loom that has broken, I believe this is what has happened here. I'm looking for a wiring diagram from all the connectors/ports of the box back to the ECU to test for continuity. This was a problem before I took the box out so it possible doesn't matter, but to me it does.
Regards
