1973 DS handbrake
dustyLHM
1973 DS handbrake
Have parking trouble on hills . How are the handbrake pads removed ? Is it needed to remove callipers ,or if possible,e to remove after withdrawing holding bolt through slot in pad, also have same problem on hills with SM, dustyLHM
- x 1438
Re: 1973 DS handbrake
Welcome to the forum. I am sure that someone with some experience of DS brakes will be along shortly, I know about handbrake pads on old Jags, where you need to dismantle the handbrake calliper to change the pads, but don't know if the DS/SM are similar.
