Just changed my CD from factory fitted. However I have a problem Citroen c5 mk1 2003 auto
Installed new CD player and was working however CD player wouldn't turn off with ignition so I swapped wires around and it would not power up so I swapped back still not powering up. Switched back to factory fitted and this is not powering up now.
Googled the problem and it says change the f8 fuse however there is no f8 fuse the bank is empty checked other fuses and all seem ok
Any advice please
Aftermarket stereo
- x 6954
Re: Aftermarket stereo
Pop your VIN up
You'll need a specific aftermarket wiring harness for it to work properly, or expect electrical problems - these cars are multiplexed!
