C4 B7 ABS, ESP and Hill Assist faulty
Cutac
x 20
Unread post by Cutac »
Hello,
the other day Service light lit up and "ABS, ESP and Hill Assist faulty" message showed up on the display.
It happened on the startup and was gone after I've restarted the car.
Faults are these and they were all noted at the same time:
P0565
P0575
U1308
Could it be because of the dead-ish battery(12.3V when the car is off)?
x 6956
Re: C4 B7 ABS, ESP and Hill Assist faulty
Here are the fault code descriptions - As you don't have an Electronic Parking Brake, I would ignore the Hill Start functions - but all symptomatic of the ABS / ESP - if the speed info is incorrect or the data is faulty - which automatically cuts out cruise control and speed limiter functions - so that's the reason for these 2 faults. Ignore those and focus on the others. It may go away on its own if conditions are correct.
Fault codeP0565
After sales description of the fault codeCruise Control information: Not plausible or absent
Description of the diagnosticsConditions for activation of the vehicle cruise control not satisfactory
Conditions of activation of the diagnosticsThe following conditions have to be met
- Engine management ECU in main triggering phase
- Cruise control active
Conditions of disappearance of the faultVehicle cruise control is authorised following a cut-off then reactivation
Down-grade modes if fault presentVehicle cruise control inactive
Switching on of the warning lamp and/or warning message-
Main customer complaints likelyActivation of the vehicle cruise control impossible
Suspect areasBuilt-in systems interface
CAN network
ABS/ESP ECU
Motorised throttle unit
Accelerator pedal sensor
Clutch sensor
Automatic transmission control unit
Piloted manual gearbox ECU
Fault codeP0575
After sales description of the fault codeVehicle speed limitation information: Not plausible or absent
Description of the diagnosticsEnvironmental conditions for activation of the vehicle speed limiter not met
- Speed limiter active
Conditions of disappearance of the faultThe vehicle speed limiter must be deactivated then reactivated
Down-grade modes if fault presentVehicle speed limiter inactive
Main customer complaints likelyActivation of the vehicle speed limitation impossible
CAN network
ABS/ESP ECU
Throttle housing
Foot throttle pedal
Clutch sensor
Fault codeU1308
After sales description of the fault codeNo communication with the engine management ECU fault: No signal
Description of the diagnosticsPossibility 1
- The time for recording the fault code is 500 milliseconds
- Data from the engine management ECU absent
Possibility 2
- Incoherent data coming from the engine management ECU
Conditions of activation of the diagnosticsIgnition switched on
Conditions of disappearance of the faultPossibility 1
Data transmitted by the engine management ECU
Possibility 2
Coherent data from the engine management ECU
Down-grade modes if fault presentPossibility 1
- The anti-lock braking system (ABS) function switches to down-grade mode
- Immediate cutting out of all of the stability control ESP regulation functions
- Hill start assistance function inactive
- Switching of the electric parking brake to manual mode
Possibility 2
- The regulation functions remain active
Switching on of the warning lamp and/or warning messageWarning lamp ESP/ASR
Electric parking brake automatic functions deactivation warning light
"SERVICE" warning lamp
Main customer complaints likelyIllumination of the ABS and stability control (ESP) indicator lights
Suspect areasEngine management ECU downloading
ESP ECU
Cutac
x 20
Thanks!
I'll fit a new battery tomorrow, hope it solves the problem.
