Diagbox instructions to add cruise to 207 sw?
fotobright
Unread post by fotobright »
Its time to add cruise control to my 207 SW. I have installed the stalk.
I've read the forum overview about using diagbox and had a brief hook up of the software yesterday. However I can see its going to take time to understand how to negociate into and out of the software layers. The main thing before to fiddling with the ecu is to understand how to use the software properly. First question is..
Q1: Does anyone have a link to a good overview and description about how to navigate around diagbox?
Q2: As I understand it the cruise control is activated in BSI, someone got specific instructions where and some instructions or link. I only need the CC not expecting to activate the speed limiter.
Peugoet 308 SW HDI 1.6 Live*
Peugoet 207 SW Hdi 1.6
C5 2.2L HDi 16v estate (01)
Xsara Hdi 90 estate
Xantia 1.9TD estate, (veg oil)
Zx 1.9TD hatchback
Zx 1.9D hatchback
x 1056
Re: Diagbox instructions to add cruise to 207 sw?
Unread post by wheeler »
CC is normally activated in the injection ECU not the BSI, i have never done it that i can remember on a Peugeot model but done it plenty of times on Citroens. It is usually listed as RVV which I believe is the French abbreviation for cruise control.
Here is a guide for a C5 which should be similar > https://frenchcarforum.co.uk/TechDocs/C ... trofit.pdf
x 6957
Ensure you have the correct brake switch too and don't forget to read the advisory section on using Diagbox first of all:
Diagbox Warning
