Is there a forum post here step by step for someone who is not updating but is installing from a fresh start?
Is there a download of a full version that bypasses the need to install an old version and slowly install updates?
Google suggests version 7.83 with download sites like this
https://blog.cardiagtool.co.uk/diagbox- ... st-review/
Why does this page speak of V9.12 ?
http://blog.obd2diy.fr/2017/11/17/psa-d ... 3-11-2017/
At bottom of this page there is numerous links to different versions.
Can it be explained what is "Leave the network adapter switched on but not connected to internet"
How to do that with laptop and wifi router?
Does it work with Windows 7 (websites talk about Win XP)
My car C4 Picasso 2013 mk2 1.6 Hdi
Thank you
Diagbox versions
- x 3296
Re: Diagbox versions
I am using V7.15 (on a rev B chipset) on a Toshiba NB250 running Windows 7 Starter. It has been used on a C5 X7 (I cannot remember the year) to activate the DRLs.
Reason: Edited for incorrect info
- x 6945
In no particular order:
Instructions for installing should be included with your purchase, but are widely available on the net.
No - updates should be installed incrementally, as the necessary firmware for the VCI is also installed depending on version.Is there a download of a full version that bypasses the need to install an old version and slowly install updates?
Ignore that - the version of Diagbox is dependent upon the vehicle it will be used on. Generally 7.58 is the most stable and covers vehicles up to December 2014. Version past 7.60 start to remove manual telecoding optionsGoogle suggests version 7.83 with download sites like this
It means you must leave your wireless network adapter switched on and enabled, but do not let it connect to a live internet connection. This is because it needs access to the network adapter to get the hardware MAC info to do with the activation. So just make sure you disconnect from your home internet network during installation, so that it cannot get internet access.Can it be explained what is "Leave the network adapter switched on but not connected to internet"
YesDoes it work with Windows 7 (websites talk about Win XP)
