Peugeot 5008 2.0 hdi eolys tank capacity
valentim1973
Unread post by valentim1973 »
Hi all , wondering if someone can answer a question of which is the capacity of the Eolys tank in PUG 5008 2.0HDI 2010 ? Regards Luis :wink:
x 6955
Re: Peugeot 5008 2.0 hdi eolys tank capacity
I'll need your VIN to determine this.
valentim1973
Hi Mark the VIN is VF3**************[VIN obfuscated, can be read by forum staff], thanks for reply.
x 6955
Ok, so it's standard tank and not a pouch, so at factory these are about 3 litres. They only need topping up when you get the additive low warning, and then you have a bit of time to get it done. The engine ECU determines the amount in the additive tank based on the mileage done, mileage remaining until next service (and on this basis determines when the light is put on). The amount remaining in the tank is not a physical measurement, but a calculation. If it thinks there is not enough additive in the tank to make it until the next service, it will throw the light on earlier than say if the expected service interval is only a few thousand miles away for example.
valentim1973
Thanks Mark for your help and yes it will be filled with eolys 3rd generation tomorrow and system reset afterwards , regards Luis
