Well here we go again.
What version of Lexia/PP2000 do I need for a
Citroen 2011 C5 X7 1.6 e hdi stop start with the egs6 gearbox. I do believe that my random clutch slip may be due to needing adjustment via the Lexia.
Good old Lexia
renagade
- x 10
Good old Lexia
There are so many roads to travel but so little time, (Paul Cofield )
- x 6945
Re: Good old Lexia
Neither!
You use Diagbox for this year. V7.58 will be fine.
I'm not sure there is anything to do in Diagbox - it should all be self adjusting.
- x 1490
Re: Good old Lexia
There's a procedure somewhere for adjusting the clutch biting point on an EGS - however, I think it's possible just be doing a series of swift take offs in a row as well....
- x 6945
Re: Good old Lexia
Yes, that was my recollection too - I'll have another check.
- x 6945
Re: Good old Lexia
As far as I can see it only requires the following operations if the Hydraulic Clutch Stop has been replaced:
- Pressurise and bleed the hydraulic circuit
- The initialisation of the clutch engaging point
- The initialisation of the gearbox grid
- Programming of the engine torque value transmitted to the clutch
