reset paf level
KennyW
x 165
reset paf level
Unread post by KennyW »
Good Afternoon,
I think I have finally got my Diagbox working correctly.
So how do you reset the particulate additive level ?
Kenny
C3 1.4 petrol (SWMBO)
x 6945
Re: reset paf level
You'll need to go into the injection ECU and from there should an option for 'Pack Repair' or such - where you then see the option for the additive / set the additive level to zero. It should be a guided instruction from there.
KennyW
x 165
Re: reset paf level
Thanks Marc,
I was unable to check further as it went into eco mode.
Can this be done with the engine running ?
Kenny
x 6945
Re: reset paf level
No not really, as at some point it will ask you to switch the ignition on and off I suspect as part of the routine and needs to be off to initiate the procedure I believe.
x 1489
Re: reset paf level
I've done a couple, depends on what's fitted. Might be in the engine ECU, might be in the DPF ECU if fitted - or might need both! You can probably leave the engine running whilst you find it, then you might need to switch it off to actually do the update - but it shouldn't go into ECO in the short time needed for this....
x 6945
Re: reset paf level
No separate Additive ECU on the X7 Richard, all done from the engine ECU.
KennyW
x 165
Re: reset paf level
Thanks for the replies Marc and Richard,
Just getting use to the 'working' Diagbox. It lasted about 30 minutes before it went into eco mode. I left it running (laptop) when I helped my neighbour.
Kenny
KennyW
x 165
Re: reset paf level
reset done.
x 6945
Re: reset paf level
Excellent, no issues then Kenny?
KennyW
x 165
Re: reset paf level
None Marc,
But every Global test done electric suspension ecu comes back, error in communication, there is one other ecu that does the same can't remember which one.
if an ecu is not fitted it states so.
What is the issue ?
Kenny
x 6945
Re: reset paf level
If it’s the CSS ECU error, ignore it. That relates to the separate suspension ECU on V6 models, that is not fitted to other models. Non V6 models have the ECO suspension ECU incorporated into the BHI (integrated hydraulic unit).
If you can post up more details or the exact error I can confirm this Kenny.
KennyW
x 165
Re: reset paf level
Thanks Marc, will check the message again and get back.
Kenny
