Got a set of weird issues with my dad's DW8 Partner that I cannot for the life of me seem to figure out what is causing it.
Firstly whenever you are going up a hill or trying to build up speed past 35 mph even with your foot down it misfires really heavily with a lot of black smoke. Weirdly every now and again it will gain power out of thin air and catch you off guard.
Tried unplugging the EGR and it ran like a bag of spanners so we know that is functional at the very least. Also unplugged the Maf sensor, temperature sensor (it kicked on the fan as expected) and all of it is working as it should be.
Also it has recently developed a problem with what I suspect is the glowplug relay where it either takes 2-3 attempts of turning the ignition on and off to get the glowplugs to work or you have to roll it down a hill.
One night in particular it was struggling we rolled it down the hill to get the glowplugs running and it started but it was really rough while the engine started and completely covered a carpark full of thick black smoke
The Final issue is an intermittent one where if you have the drivers side door open and you blip the accelerator it causes the dashboard lights to flicker and the door open beeper to sound as if you've just opened the door.
I have videos of when it covered a carpark full of smoke and when the dashboard flickers if you need to see what is happening.
Any suggestions will be greatly appreciated,
