C5 MK II DW12TED4 Engine Fuse Box 6500CK
x 6945
This is the engine fusebox for the C5 in the title thread for member 'cfiver'.
Relays are indicated on the second diagram, so you'll have to use this as a guide when tracing the fuse connections on the circuit board to try and identify the ones on your board in question.
Main Fusebox
Diagram
Key
FusesAmpMatching
F120ADiesel Heater - Engine Management Ecu - Petrol High Pressure Regulation Electrovalve - Diesel Fuel High Pressure Regulation Electrovalve - Turbocharged Air Heater Electrovalve 1-2 - Diesel Injection Pump - Water In Fuel Sensor
F215AHorn
F310AFront/Rear Screen Wash Pump
F420AHeadlamp Wash Pump
F515APetrol Pump Supply - Canister Purge Electrovalve
F610AAnti-Lock Brake Control Unit - Esp Ecu - Relay 3 Protection Switch Unit - Heater Unit (Diesel)
F710AAutomatic Transmission Control Unit - Gear Lever Blocking Actuator Control Relay - Automatic Gearbox Control Assembly - Automatic Gearbox Electrohydraulic Block - Power Steering Electropump Unit
F820AStarter
F910ABrake Dual-Function Switch
F1030AIgnition Coil - All Or Nothing Electrovalve Supply (Egr) - Injector Cylinder 1 - Injector Cylinder 2 - Injector Cylinder 3 - Injector Cylinder 4 - Canister Purge Electrovalve - Engine Management Ecu Supply - Lambda Probe - Air Flowmeter - Diesel Heater - Water In Fuel Sensor
F1140ABlower Motor
F1230AWindscreen Wiper Motor
F1340ABuilt-In Systems Interface
F1430AExhaust Air Injection Pump Power Supply
Mf150AVariable Speed Cooling Fan Assembly
Mf230AAnti-Lock Brake Control Unit - Esp Ecu
Mf330AAnti-Lock Brake Control Unit - Esp Ecu
Mf480ABuilt-In Systems Interface
Mf580ABuilt-In Systems Interface
Mf680ACabin Fusebox 12
Mf770APower Steering Electropump Unit (Ew10a (Rfj) - Dw10bted4 (Rhr))
Mf840ACentral Electronic Block Motor
