Bit unsure which topic to put this under but here goes. I have a Citroen relay 65 reg, only came with one key so I need another. I have experience with opcom for Opel/Vauxhall cars and rather than go to main dealer would like to programme keys myself. Does anyone have any experience with obdstar h108 psa? On internet it looks pretty good although I’m yet to find out if it would work with my van. Or does anyone have any recommendations? I have seen Lexia, but I noticed a lot say that they work with windows 7 or earlier so not sure if I could get one that would work on windows 10.
Thanks everyone, Jon.
Key programmer
- x 6963
Re: Key programmer
Lexia is a software programme maintained for older vehicles (circa 2006 and earlier) and is bundled within Diagbox, which is the main software package used by PSA group and others. Diagbox works with all the later vehicles in the group, launching the most appropriate software for the vehicle being worked on. Diagbox will work for Citroen, Peugeot & DS Automobiles. It uses a VCI hardware interface and requires a suitable laptop to run.
It will work on Windows 10, but the 'Lexia and Peugeot Planet 2000 (also bundled for Peugeot) will not run directly on any 64 bit version of Windows (including 10), as Lexia and PP2000 were made using 16 bit code, unsupported in 64 bit editions of Windows. You will either have to use a 32 bit version, or set up a virtual machine under the 64 bit Windows you have and run it from there. You may also have to change the BIOS back to IDE mode from AHCI and the hard disk partition will normally need to be set to MBR not GPT. So that may impact on any existing programmes you may have.
It's another reason why it is highly recommended to have a dedicated cheaper laptop to use for diagnostics and not one that you use for anything else - apart from what I've already described, the Diagbox installation is very messy and creates folders all over the place!
Diagbox is the proprietary software used by PSA and is far more than a diagnostic tool, providing advanced fault finding and guided procedures for certain operations, including key coding for example. If you have one or more PSA vehicles and are considering having more in the future, then this has to be seen as an investment really. Third party code readers just don't cut the mustard. Installation can be fiddly and pre-conditions need to be met, because of all the variation of installation scenarios and different specs and hardware out there. It is also important if considering purchasing one, that you get a 'Full-Chip' unit Revision 'C' unit, as there are cheaper units being sold out there that are cut-down versions and many have communications issues with some later vehicles.
If considering, have a look at the Announcements section of the diagnostics Forum to find details of a discount for forum members from a recommended UK supplier.
Jlm19900
Re: Key programmer
Thanks for the response Marc, I have had a look on the website which you said about and it says they are out of stock there so I will have a look around. If I get a lexia interface and download the Diagbox software then I can’t go far wrong? I’ll have a look for a cheap laptop running 32bit windows as well. Thank you
Jlm19900
Re: Key programmer
Thinking of buying these two, seems like a good combination, not too expensive and does the job.
https://www.ebay.co.uk/itm/FULL-CHIP-RE ... 1751630895
https://www.ebay.co.uk/itm/CHEAP-HP-Com ... 0740510800
- x 6963
Re: Key programmer
Try and get one with a minimum of 4Gb RAM, the faster processor the better of course. Installation instructions will be supplied with the ones from Easydiagnostics - they do sell out quite quickly as they are very popular, but do get stock back in regularly.
- x 6963
Re: Key programmer
The Lexia kit looks fine, but forget the laptop - not enough welly and short of RAM - it will be too slow.Jlm19900 wrote: 30 Dec 2018, 12:49 Thinking of buying these two, seems like a good combination, not too expensive and does the job.
I have one of these:
https://www.ebay.co.uk/itm/CHEAP-Lenovo ... ctupt=true
Also allow for a battery replacement on any second hand laptop, as it's extremely likely that they will have done their duty cycle. I got a higher capacity battery for mine when I got it as it would hold the charge very and that's not good for doing any diagnostic work on a car when you are connected up to the systems.
Jlm19900
Re: Key programmer
Good find, cheers for that. Thinks that’s the setup I will get then, along with a 7800mah battery and should be great.
