Headlamp washers
Stempy
Headlamp washers
Another thing on my list of non working bits on the Xantia is the headlamp washers. Must be a common thing as they packed up on the last one too, but I never got around to tracing the cause. I know they work from a timed relay if you wash the screen with the dipped beam on, but I never managed to find out which of the numerous relays it was. Anyone know[?]
Rich
Hi Stempy,
I'm having the same problem with my Xantia HDi Exclusive. I found out from an independent garage that the relay was missing and that was the only problem, so they shorted out the contacts on the car with a piece of wire so the washers would work. This i was not happy about so i tried to get the relay from Citroen. They told me they don't list one![xx(][:o)] Anyway, on my Xantia, (you did not say what your exact model was...) the relay is located in the black plastic relay box behind the battery and fits in the five pin socket marked with a number 2. I don't know if it will help, but i did read in the Citroen Car Club magazine a few weeks back about a guy having the same problem and he mentioned a part number for this relay, it is; 655551 and the relay is apparently a big grey one. I'm going to show this information to a Citroen dealer and see if i can obtain this mystery relay!![:D][:D][8D]
Cheers, Rich. Xantia Exclusive HDi.[^][:D]
Stempy
Stempy
Well, had a look at the relay mentioned, it is in a PINK casing and inside is a small circuit board with an IC and various other components which I would imagine is the timing circuit. Tried jumping the relay manually but still no washers and then I ran out of time so will have to go back to it.
While I was under the bonnet I noticed that one of the cooling fans has fallen off the motor spindle and obviously the screw is missing, would I be right in assuming it is a left hand thread, and what is the likely hood of getting one as a spare part?
Stempy
