Brake pad replacement on Partner Tepee
Pete27
Unread post by Pete27 »
I have brought some new brake pads, which I have found are directional. There are no marks and double chamfers. I checked the Ferodo web site and it says fit the larger chamfer to the leading edge of the rotor.
My question is, when it says larger chamfer, does this refer to the steeper angle or the larger surface area.
Many thanks
MikeT
x 232
Re: Brake pad replacement on Partner Tepee
Unread post by MikeT »
The most worn edge is the larger chamfer. ie, less contact area.
