No power at fuse box
hoohgoo
Unread post by hoohgoo »
Hi all I have a 206 gti it had an anti pollution message and was running rough would not go over 3000 revs tried to drive her home and conked out came up briefly with immobilizer fault now saying eco mode and no power at the fuse box (under bonnet) had someone to look at it advised I change the fuse box which Iv done still no change the box I ordered didn't come with the piece where the fuses underneath are so that is still the same PLEASE HELP dont want to have to put the old girl to sleep :-D
x 6954
Re: No power at fuse box
Another reason to get it properly diagnosed with Peugeot Planet 2000, in order to deterimine the fault codes and the issues. The engine fuse box won’t really have anything to do with putting the car into limp home mode. That will be down to the engine management ECU enabling a backup mode because of either a pollution fault or to protect the engine, until the fault is rectified.
Without a diagnostic, it will be expensive guesswork.
hoohgoo
unable to connect due to no power at box
hoohgoo
yes I agree about limp mode need to fix the fuse problem to be able to run a diag
x 6954
Are you getting the engine fuse box confused with the BSI?
The diagnostic port is on the BSI in the passenger compartment. If there is no power to the BSI then you won’t be able to use the remote control to unlock the doors, start the car etc.
I would check all the fuses and maxi fuses in the engine fuse box first, as one of these supplies power to the BSI.
hoohgoo
The fuse for the diag port is in fuse box under bonnet though right?
hoohgoo
Have checked fuses need to figure out why there's no power getting to fuses
x 6954
Pop up your VIN and I’ll check out the circuit diagrams for you.
hoohgoo
VF3**************[VIN obfuscated, can be read by forum staff] thankyou
x 6954
Ok, I've had a look and because of the model changes in the 206 about this time, you could have 2 types of electronic architecture and several variations of fuses and fuse box types. The diagrams I have are not helpful as there are no descriptions for any of the Engine fuse box / BSI or older types, which doesn't help much. It's just because by the time they started centralising all the data, some early models dipped out of getting all the info on.
Having said that, this link may help you identify the type of engine fuse box and electronic box in the passenger compartment. It has photos and if you follow down, a legend for the fuses. I hope this helps you to identify the relevant fuses:
https://fusesdiagram.com/peugeot/fuses- ... t-206.html
As you can see there are lot of variations, but hopefully this will give you a few pointers to start with. :wink:
hoohgoo
thanks for looking both are type 1 have look at this site before have looked at all fuses whats the next course of action what would cause no power to box? thankyou for your help
hoohgoo
would it be worth changing maxi fuse mod?
hoohgoo
when I bridge wire from batt to fuel pump fuse can hear it start?
x 6954
I can only suggest you recheck the fuses (especially the maxi fuses) and with a multimeter, not visually and all the wiring - especially the earths to the body. If you are sure you have fitted the correct replacement fuse box (check part numbers are identical), then it very likely has to be wiring / fuse related. Your best friend here is going to be a multimeter. If there is power at the engine fuse box, then check the connections to the BSI in the passenger cabin - as it may be that one that is faulty if there is no power to it and you can't run a diagnostic.
We have to assume your battery has been checked and is fully charged - if you have an old battery that is past service life that can be a problem.
hoohgoo
what wires are power a box under bonnet please
