2009 308 air con
alanty
2009 308 air con
Unread post by alanty »
Are there any relays on the air con if so can you tell me the location
Thank you
x 1438
Re: 2009 308 air con
Unread post by xantia_v6 »
I don't think that there are any user-serviceable relays, the compressor and servo motors are directly controlled by ECU, and there is an electronic module controlling the blower speed.
What symptoms do you have?
It will probably be necessary to have the fault codes and parameters read to localise a problem.
alanty
The symptoms are the switch lights up when you press and there is a slight raising of revs when on idle and no power to low pressure switch
