recently a friend of mine did a hub conversion (from four studs to five studs) on his Honda. He said I may be able to do the same to my Citroen AX (three studs to four studs). The problem is..where the hell can I get suitable wheel hubs for the AX. Are there any conversion kits for the AX in the market today ?
cheerz to all !!!
AX wheel hub conversion
- Contact:
- Contact:
A friend of mine has done this on his AX.
He used SAXO/ Pug 106 parts.
The AX GTi has 4 studs on - so parts off that tshould work too!
New suspension struts are requires on the front and a new rear beam for the back.
I though it would be a case of changing the rear brake drums - but i dont think its as simple as that.
Try going to:
www.ax-rated.co.uk - sure you'll find some more help there too!
Oh just read that you are from Malaysia. Good luck in finding the parts.
Isnt the AX a proton over there?
<hr noshade size="1">
Jonathan
95 AX Cascade 69k
89 AX 11RE 135k
Try going to:
Jonathan
95 AX Cascade 69k
89 AX 11RE 135k
yep, the AX is called Proton Tiara in Malaysia but actually it is 99.99 AX. They only changed the emblem. Recently I managed to find a citroen emblem and put it to my car.
I've checked all the parts inside the car and I haven't found a single part that's Japanese made (Malaysian cars have lots of Japanese and Taiwanese parts). All I can see are parts which are made in France, Spain, Italy (practically all EUs). Therefore I refer to my car as an AX.
anyway, thanks for the advice. I'll try to find the neccessary parts and bits from the UK or anywhere.
Cheers !
Cheers !
