2011 C5 1.6 HDI misfire
digger58
First post here, so hello, of course looking for help, My C5 was driving fine last night, went to move it this morning and its sounds as if its only firing on 3 cylinders, It had 4 new injectors last March and has been perfect since. No lights and my code reader says no codes but I do get a misfire message. Any help welcome, TIA
- x 3296
Re: 2011 C5 1.6 HDI misfire
Hi, and
to the Forum. What kind of code reader did you use? Most of the generic code readers struggle with PSA cars. The Lexia system can handle Citroens and Peugeots.
- x 6945
You’ll probably find your code reader isn’t able to read the BSI properly. There are a lot of constructor codes that cannot be read with generic readers to be honest.
The best thing you could do is get it properly read by Diagbox, then post any codes up here.
digger58
Thanks, its a cheapie from Aldi, Whats the best to get for the C5, ;eads and software? I have Multiecuscan for my Fiats. Think I'll have to invest again.
- x 6945
A Lexia kit, which will do all PSA cars (Citroen, Peugeot & DS), so an investment if you intend having any of these cars. Not cheap but slightly more than the cost of a diagnostic at the dealer. You'll need a laptop with ideally with Windows 7 32 Bit too.
Ensure you get a revision 'C' unit. There is a discount for members from a supplier many members use:
Post containing link:
viewtopic.php?f=13&t=60113
