Removal of radio
This unit is the MyWay system, also referred to as RNEG, made by Harman Becker.
Main Features: Also referred to as RNEG, the MyWay colour satellite navigation system, has SD card, integrated European mapping, live trafic information, voice guidance and graphics in 2D or aerial perspective & it features a Bluetooth® system (Bluetooth phone compatibility only - no Bluetooth Audio Streaming).
admiral51
(Donor 2026)
x 391
Removal of radio
Unread post by admiral51 »
Just a quick question
Do you need to disconnect the battery to remove the radio.
Not to replace it but to see if something has dropped down below it into the depths of the centre console. :oops:
Thanks in advance
x 3565
Re: Removal of radio
Depends on how far you need to pull it out to see what's behind ! There's a certain amount of slack in the cabling, and probably enough to shine a torch into the depths to see what's lurking in there, but if you actually need to completely remove the radio and surrounds to get at anything that's dropped down then it'll all need to be unplugged, which would require the battery to be disconnected..... if you 'go by the book' :wink:
You'll need 4 of this design of key (PC5-132) to remove the RNEG radio - and the keys are especially sharpened on the edges to cut your fingers as you wrestle with them :roll:
https://www.ebay.co.uk/itm/VW-CD-RADIO- ... 0785764247
admiral51
(Donor 2026)
x 391
Thanks for that,have the keys so will disconnect battery for 30 mins before i start
admiral51
(Donor 2026)
x 391
all done and what had been lost has been found :)
