Citroën Despatch 1.9D 97-98 /Glow plugs or relay
johnnyb48uk
Unread post by johnnyb48uk »
i have a box what am pointing to , has bad time starting in the morning when cold now mybe the glow plugs , or relay or this box next to it , i touched it and it cut out . it was corroaded abit cleaned it a bit , and glow light come back on and started . can anyone tell me what it is plz or problem any question ill tell you thanks Image Image
x 6957
Re: Citroën Despatch 1.9D 97-98 /Glow plugs or relay
Hi and welcome.
That does look like the Glow Plug Relay and these are relatively cheap to replace.
Post up your VIN and I'll confirm the correct replacement part number for you.
x 1751
Not sure about the small box/unit, but the big box is the glow-plug (GP) relay.
Known for corroded/dirty contacts on the underside (which can also overheat - swollen cable insulation is a clue) which should be cleaned up back to bright metal.
>>> Disconnect the battery before unshipping the ring connectors, as one of them will be permanent Batt+.
The GP relay can be opened up to check the internal contacts. These handle a heavy current, and can become oxidised. Clean up with fine glasspaper. The relay also controls the GP indicator light on the dash.
New relays readily available, as Marc says.
johnnyb48uk
the little box , i moved it and it cut the engine off , i tried to start it again , and the glowplug light didnt come on ?? i took the small box off the connecter and give it a little clean , re plugged it back on and toucked it behind the big box , the glow plug light came back and started , Am wondering if it has been piggy backed some how , for some reason ??
x 1751
I don't recognise the small plug-in box.
If you can post your VIN number, maybe we can help identify it with a circuit diagram.
x 1056
Unread post by wheeler »
Is it a 9 pin plug? It looks like the very primitive type main relay that powers any engine sensors & the keypad immobiliser system (if fitted). I think Citroen call it the ADC relay.
Looks like someone has butchered its connector, there should be a sliding tab on the plug that needs to be pulled out to release the plug from the relay. Its deffo factory fitted.
