03 plate undertray and owners manual
picassodad
x 15
Unread post by picassodad »
Thanks marc......
the lad is chasing the owners manual on e bay......
please could you show the exploded view of the possible engine undertray for this car, it did not come out of the factory with one ?
There are several types shown on e bay but a picture of the proper one is gunna really help.
I imagine the proper undertay will have a centre section hole for sump cooling ??
Thanks...
x 6962
Re: 03 plate undertray and owners manual
Yes, this model did not have the underbody protection - not available for the petrol engine. As they are all different and moulded for the different engines, they need to fit the right engine type, so as none are listed for the petrol engine at all - there's no point in showing them I guess. :)
picassodad
x 15
Thanks for that, i will make one then with a "hole" for sump cooling.
oscar
x 8
Unread post by oscar »
Best way is with some sheet alloy once shaped/cut to fit bond some thin plywood if need be to absorb flex and vibrations
Fixings for diesel model should fit might need some spire type clips where fixes?
Find a tray from somewhere or borrow from someones car! to make a template with likes of brown paper.
If was this way could have mine
Fake Concern
x 65
Unread post by Fake Concern »
Why do you want an undertray?
Michel
Unread post by Michel »
Why do you want the hassle of an undertray? If it didn’t come from the factory with one, it doesn’t need one.
picassodad
x 15
Yeh, quite, but the aux drive belt area is exposed and just asking to ingest some road debris etc....i have my eye on some dumped alloy sheet on some waste ground, thats big enough to make a bespoke under tray. I will make it so its easy to remove and hassle free for oil and filter changes etc.....
x 1751
Undertrays are usually made from something like 3mm thick heavy black vinyl-like material - similar to a thick floor covering. This is acoustically dead (won't vibrate), will take knocks etc from stones, and won't rust/corrode.
If making something up for yourself, would suggest doing it in cardboard first, and when the shape is right, copy it to the final material.
I do understand why you think this is a good idea: keeps road grot out of the engine/subframe/electrics, and protects vulnerable belts.
Last one I bought new (for XM 2.5TD) was €300 (around 10 years ago), so DIY is an attractive option.
You might find a scrap diesel one for your car somewhere, which could be modified. Subframe shape might (might) be same sort of shape.
x 6962
A word of caution - the OEM ones are made of a more flexible material so that if / when they come off in an accident or through catching or hitting something, they minimise damage to the engine components / pedestrians, as flying sheet metal can be lethal - so I would be aware of that and advise against it. Metal ones may interfere with the 'crumple zones' or the design of the front of the vehicle to absorb an impact and deform in an accident as intended.
I've had the original standard plastic moulded ones come off after some debris on the road hit at speed and that made a hell of a racket and caused the front part to come off downwards and the wind drag caused the front to hit the road and then it catapulted and flew off - so a metal one could be lethal. I think mine through routine servicing invariably had some clips missing - common enough it seems, but regardless I still wouldn't recommend it. I wouldn't like to think of the possible legal ramifications if you did cut somebody to shreds.
Here's an example of a metal one somebody obviously fitted as this is definitely not standard equipment! [-X
Their main function is to protect certain vulnerable parts of diesel engines (especially HDis) according to Citroen, that's why the petrol ones don't have them.
x 1751
Useful distinction between an undertray and a sump protector.
Forgot to mention that one of the functions of the diesel model undertrays* is to reduce engine noise (at idle/slow speed) for pedestrians.
A metal one could have the reverse effect, of actually reflecting engine noise upward, rather than allowing it to get lost towards the road surface and general airflow; not a good idea.
* which can also have sound-absorbing foam on the upper side of the tray
oscar
x 8
white exec wrote: 01 Nov 2018, 10:58 Useful distinction between an undertray and a sump protector.
thats why i said stick something to it but aluminium is quite good at sound absorbsion as soft so deforms enough in an impact reason rally cars have theres made from it
If caught hard enough will pull through fixings and deform and could even rivet a scoop in front end of it as gives you room for being creative
One thing is to brace across it from each side so unlike the plastic ones don't hum at speed as they often flap up n down which then leads to fastenings coming adrift as seen loads doing it on motorways etc
picassodad
x 15
A tray to stop road debris/water/road salt etc. from becoming involved with the aux drive belt, and to keep the under engine/engine bay area slightly cleaner, rather than a full bash plate, its a road car not a rally car.
Under tray on the pug fitted as standard works a treat on that car. Its been repaired as some of the plastic had broken/cracked etc., and the front of the tray is held on with some 22 cable ties. The rest of it is held on with oe clips ( 4 ) and 2 bolts with washers.
x 1751
Just noticed that there are a huge number of (diesel) car undertrays on the web, some as little as £30, and made from what looks like OE spec HDPE.
Might be worth a search, eg for a 306 D item, if a petrol version is not offered.
Michel
picassodad wrote: 02 Nov 2018, 11:15 A tray to stop road debris/water/road salt etc. from becoming involved with the aux drive belt, and to keep the under engine/engine bay area slightly cleaner, rather than a full bash plate, its a road car not a rally car.
I had one on my Berlingo, same engine, same auxillary belt positioning. It didn't really have any effect for the above - the belts, even though they look exposed stay pretty clean, even in the depths of manky winter. Mine did 80k in my ownership, on one belt, despite only having the undertray on for the first 6 months of my ownership. The Picasso I am looking after at the moment, a 2.0HDi has one, which amazingly for an 03 plate, is still all there and has all the fasteners!
