Abs light
wazzy
Abs light
Unread post by wazzy »
Abs light on picasso 1.6hdi xsara 2006 staying on diagnosis showing no fault codes need Help :!:
x 1488
Re: Abs light
What are you trying to interrogate it with? A simple code scanner might not cut it - it needs to go on Diagbox. If the light is on, then there should be a fault - unless the ECU has completly turned its toes up, in which case there might be no comms!!
x 6957
Re: Abs light
Yes - you need it on Lexia to get the fault code.
picassodad
x 15
Re: Abs light
Unread post by picassodad »
I'm no expert and have very very little experience on these cars........if its the pug 306 type abs sensor, the "blade" type sensing externally onto the castleated ring on the cv joint , they are a bit more simple ( and reliable ) compared to the internal sensing on the rubber ring inside the bearing, a bloody night mare.
Which type do you have and has any work been done on the brakes recently??
You have a reasonably good dmm?? if not they do not need to be mega expensive, no more than £20 or so unless you have money to burn and get one with a scope, or better still a good scope......
ask santa for an early gift, a £25 ish dmm. they will pay for themselves in no time.
picassodad
x 15
Re: Abs light
How you getting on ?
wazzy
Re: Abs light
Hi light still on had diagnostic still showing no fault it is same as pug has ring on the rubber part
