Hi all
mfr
Hi all
Unread post by mfr »
Pls I want wiring diagram for Peugeot partner 2013 for cooling engin van and wiring diagram for alternator
x 6955
Re: Hi all
You'll have to post up the 17 Character VIN if you want wiring diagrams.
mfr
Re: Hi all
x 6955
Re: Hi all
I think you have some of the numbers the wrong way round: Should be N9H not NH9. According to the data, this is a Citroen Berlingo, not a Peugeot Partner?
BERLINGO PRIVATE VEHICLE (B9) M1-N1 MIXED BODY TYPES 1.6 HDi 92 (DV6DTED) Manual gearbox 5
I'll put up a diagram shortly.
x 6955
Re: Hi all
Alternator:
x 6955
Re: Hi all
Cooling Fan
Raymondinio
Re: Hi all
Unread post by Raymondinio »
GiveMeABreak wrote: 22 Oct 2018, 16:19 Alternator:
Hi was this alternator diagram from service box & under what subsection please ,I can find it in mine but it's a static diagram was hoping to find the more interactive diagram where you can hover over over a connection and it shows a trace on where the connection goes to .
I'm not too sure if it's available for my Partner Teepee 2012 ?
Many thanks
x 6955
Re: Hi all
Not all the schematics have that feature and there is nothing you can do if it doesn't.
x 1056
Re: Hi all
Unread post by wheeler »
As said above it depends which particular diagram you are viewing if it has the ‘interactive’ feature however there are usually more detailed diagrams that show you the exact route the wire takes. When you have the diagram up on the screen look to the menus on the left & if its not the interactive type you will usually see installation, principle & wiring (again depends on the diagram).
These options are the other parts of the diagrams that show routing & locations. i just picked a random diagram so this just shows 2 options but this one shows the route the wire takes.
karme
Re: Hi all
Unread post by karme »
pls i want citroen berlingo b9 abs wiring diagram
