I have seen an aftermarket front parking sensor kit that I like the look of. Its a 4 sensor kit that it actuated by a press on the brake pedal and stays on for a short while after the brake press. Ideal for parking my auto C5.
I will need to find a 12v for brake lights and reverse lights ideally near the fusebox by the glove box.
Has anyone done this? Or have any wiring diagrams?
Many thanks.
Front parking sensors (aftermarket)
EDC5
- x 130
Re: Front parking sensors (aftermarket)
On my C5, someone had installed front parking sensors, the cables came through the bulkhead behind the brake pedal itself as there was a grommet there.
I'm honestly not sure if the brake switch you need to access is on the drivers side or passengers side in the RHD C5's. There are plenty of places to tap power from at the fusebox via the use of a add-a-fuse connector.
