2003 406 HDI 2.0 DOHC 16v
Charliedog7
Unread post by Charliedog7 »
Does anyone know how/where I can get a schematic diagram of how the HP fuel system works from the start in the LP fuel tank to return to the said tank. I have a problem where the engine hesitates at about 1300 rpm and again at 2500. if I press the accelerator quickly the engine stalls there is also a knocking just before it stalls. Any help/advice would bed greatly appreciated.
Charliedog
Reason: Created Separate Topic
x 6953
Re: 2003 406 HDI 2.0 DOHC 16v
I split this topic from the other thread as your question was unrelated to the ABS issue. Please create a new thread if you cannot find an existing one to ask your question.
So now we need clarification - what car is this for and what is the VIN?
Charliedog7
Re: 2003 406 HDI 2.0 8v Rapier
Marc, Sorry if I have confused you. I have had this particular problem for a good while and have changed the following parts, LP in-tank fuel pump, HP Pump Control valve, Common rail Sensor
Charliedog
lp
