Hi
I think the transducer in broken. Could somebody tell what is the oem part number of the transducer so that I could place an order to it. The car is citroen berlingo 2.0 hdi from 2003.
Speedo and odometer not working
Raul
Citroen gsa 1299 , 1982
Citroen gs 1,2 pallas 1977
Citroen xantia 1,9 td estate 1996
Citroen Xantia 2.0 hdi 90 2000
- x 6957
Re: Speedo and odometer not working
This? Speed Control
Part: 616070 Price (UK): £80.29 inc. VAT
- x 1459
The same part is used on almost every PSA vehicle since 1994, there are lots of cheap clones (of varying quality), and second-hand genuine ones available.
Raul
Changed for the new one. Still both speedo and odo do not work . One thing I noticed that when I last time filled up diesel I put the trip counter to zero and it has read 300 meter for the full tank. What should I look next.
I connected lexia to the car and got followining faults.
Under "Display and Telematics": Intermittent fauls , No permanent positive of the display
Under Injection: Prep-post heating relay citcuit Short circuit to earth or open circuit
I checked the fuses and they seem ok. Looks like there is a bad connection somewhere.
I also connected the cruise control stick and enabled it during lexia session. Needless to say it does not work at the moment.
Raul
Turns out the drive pinion inside the diff is broken. I already got the spare part but the haynes manual says that I also need to renew the gasket that sits between the pinion housing and diff. It takes at least a week before the gasket arrives. Should I try to reuse the gasket or wait for the new gasket?
