P2015
- x 6945
Re: P2015
Nothing on that code for your engine Graham - they don't list it specifically.... Was that code from a generic fault code reader or via Lexia / Diagbox?
- x 3296
Re: P2015
There is the main problem. PSA vehicles (being French!) are a law unto themselves. You will need to get her introduced to a Lexia system to get a correct reading. There are forum members who have such devices, and are willing to help out.
viewtopic.php?f=19&t=56452
- x 3296
Re: P2015
It could be worth (if you plan on working on you car yourself) buying a Lexia clone system. OK, you will need a laptop running a Windows 32b O/S (NOT Windows 10), but the Lexia equipment is available for less that £150. As a Lexia session at a dealership can cost £50, after three sessions a Lexia would save you money (and, if you have friends with PSA cars, could save them money as well). I have an early Easy Diagnostics unit, and it has helped me (and others) to either solve issues or increase functionality (I added a Cruise Control stalk to my C5, and enabled it with said Lexia).
- x 6945
Re: P2015
P2015 is not listed under the Delphi DCM 3.4 Injection ECU Graham, which is the reason I asked about the possibility of a P0215 which is
