Citroen Peugeot DS - Interactive Phone Feature Compatibility Tool
This section is for information and posts relating to Audio Head Units, and Navigation Systems
x 6955
If you’re interested to know what Bluetooth features are supported by your PSA / DS Audio System and your Mobile Phone, this utility might be useful.
Citroen Audio System Bluetooth Phone Features
Peugeot Audio System Bluetooth Phone Features
DS Automobiles Audio System Bluetooth Phone Features
The following site allows you to select your Vehicle model, and your Audio System from a list, then your Phone model. You can also specify the software versions on each if desired.
Basic information is summarised at the top left, but for a more detailed features list:
Clicking on the info, will then provide a list of Bluetooth supported features for that Phone / Audio System. This should help with identifying what features are available on your system.
I would say that they are behind on some of the phone models (Apple in my case) - but where this is the case, selecting a close alternative should give you an idea - and if you have a newer model not listed, then you should at least get the features if supported on an older model phone.
Here's a screenshot of the the Navidrive 3D system - with main features summarised
If you select the printer Icon at the top right, you can print or save as a PDF and will get a full list of all the calling and address book features.
A sample is below from a partial printout for my System
The information is quite extensive - It seems the website was designed for mobile devices as it is a bit small but should be ok to get the printout you need. :-D
Fr3nchy
Re: Citroen Peugeot DS Bluetooth Feature Comparison
Unread post by Fr3nchy »
Too bad the photos aren't loading properly but the links are still working so I'm going to use that
Ceenine
x 17
Unread post by Ceenine »
Thanks Marc, very helpful
Don
