Hi guys,
I'm seeking your advice as I (good engineering knowledge but nothing in depth about cars) as well as my mechanic at a local garage in cornwall is stuck with following issue:
My converted campervan Citroen Jumpy (Dispatch) 120 hdi l1h1 2008 from Austria got seasick while crossing to the UK.
Things started with power steering faulty coming up and now I'm having a completly confused on-board computer with randomly flashing lights and beeps. Changing the bsi didn't help a thing.
Find below the diaries of a shipwrecked camper. I'm happy with every hint but will eventually have to bring it to Citroen who will charge me a fortune.
Cheers,
Markus
ECU Problems
18.8.2018 golitha falls power steering faulty, ps hard
19.8.2018 esp lights flashing. then esp, brakes, revmeter & coolant temp off, ventilation off
20.8.2018 M R Autos Garage
1. diagnosis gives error codes from different ecus, e.g. air suspension
2. power steering ecu plugged off. no effect.
3. car electrician with diagbox: power steering not reachable, engine fuse box must be faulty
4. second hand fusebox from ebay installed. first test rideby mechanic all working. power steering lamp on but ps working. second test ride by owner. lamps on not startable until 20 tries. same error as before.
23.8.2018 tintagel static errors: anti pollution system faulty. power steering faulty, and not working but ps 1 time of ~4 starts working. random errors: esp, abs, speedo, revmeter, vent
Weird BSI Faults with a Citroen Jumpy (Dispatch) 120 hdi l1h1 2008
isn0gud
HydroFreak
Re: Weird BSI Faults with a Citroen Jumpy (Dispatch) 120 hdi l1h1 2008
Did you interrogate each ECU to see what these 'random errors' referred to?
isn0gud
My mechanic did, as I have no diagnostics tool. So I cannot tell you exactly. It had lots of fault codes (i think most are about communication. I recall U0121 lost abs comm. Or some codes with air suspension etc. What seems to work porperly). he was able to clear them except power steering, as it is not possible to communicate with this ecu
HydroFreak
If you can provide a good level of detail from the diagnostic sessions, you might have a better chance of receiving helpful feedback here. When I do a diagnostic session I make sure that I record or print the results down to the greatest level of detail for analysis later. Personally I wouldn't have much faith in a mechanic who didn't do the same. Hopefully he has the data available for you.
isn0gud
I don't know how many garages provide their customers with printed diagnosis reports, but mine didn't. Sorry, that's all I have to offer.
Is that an 'could be everything issue' or can anybody relate that with a specific fault? E.g. wiring, power steering ecu, second hand bsi also faulty etc.
- x 1460
Random faults involving mutiple ECUs are often caused by wiring faults, possibly water ingress at a connector, or a corroded fuse.
Check all of the electrical connectors that you can find, and all of the fuses. You will probably need more time with a Diagbox to get a better catalog of issues. Maybe (if you are keeping the camper) it would be worthwhile getting your own.
I would probably concentrate on the steering ECU issue to start with, as it appears to be a permanent fault, either loss of power to the steering ECU or communication bus issues.
isn0gud
Thank you, I will try that!
I already ordered an ELM327 bluetooth diag tool (TorquePro). Let's see if that is any good.
isn0gud
Hi guys,
It's been a while so I just wanted to let you know what was the fault as it is fixed by now:
The power steering ecu that's inside the ps pump went mad (aluminium pump all corroded so probably water inside electronics) and a new one solved the problem. That did cost me about 350 gbp for an exchange unit + labour.
If you're having that issue try disconnecting the smaller ps pump communication 2 wire plug. When done so ps is not working but no other faults caused by a messed up communication bus will come up. Pump is located right in front of the front wheel where your steering wheel is and a bit hard to reach from below.
Thanks or the support! I hope that's of use for somebody else!
Cheers,
Markus
Cheers,
Markus
