HDI into non HDI
minkynuts
HDI into non HDI
Unread post by minkynuts »
I have a year 2000 Picasso non HDI that is slowly giving up the ghost. I also Have a Xantia 2000 HDI with an engine that has only done 100,000 miles and is in perfect condition. Is there a way I can drop the HDI engine into my Picasso
x 1240
Re: HDI into non HDI
Unread post by Peter.N. »
Mechanically it shouldn't be to much of a problem but unless you are well versed in electronics I would give it a miss.
Michel
Unread post by Michel »
minkynuts wrote: 19 Aug 2018, 09:21 I have a year 2000 Picasso non HDI that is slowly giving up the ghost.
I presume your Picasso is a petrol because As far as I'm aware, they never made a non-HDI diesel Picasso. It started off with the 1.6 and 1.8 petrols, and the 90BHP 2.0HDi. There was never a old fashioned diesel version.
It would be *far*, *far* easier to buy a decent Xsara Picasso HDI, cheaper, and much better for your mental state. You'll have to change *every* last bit of wiring, BSI, ECUs and more..
x 6957
Yes, correct Mike - no non-HDI Diesels on the Xsara Picasso. I would also have to agree with the above, as it is not just the electronics that need to be compatible, but other major components that won't be compatible.
Michel
GiveMeABreak wrote: 19 Aug 2018, 15:05 Yes, correct Mike - no non-HDI Diesels on the Xsara Picasso. I would also have to agree with the above, as it is not just the electronics that need to be compatible, but other major components that won't be compatible.
I had a shonky old Xantia HDi 110 some years ago, and a lovely Xantia Activa, which was mint, I used it every day, but it was thirsty as hell. I know they made and Activa HDi, and I think with a remap on the 110 motor, it would make a lovely car. I therefore looked into doing an engine swap between the two, and it would have been an utter nightmare to do.
