Hello,
I would like to ask what is this at the photo below... is it carburetor??the car is a 11/10/1993. (dd/mm/yyyy) 306 with engine code KDX10FS5Q1396536...
Thanks a lot for your time!!!
The photo is : https://1drv.ms/u/s!Ajh4BEgtwMzcbBUSXi0C9SZU5gU
Whats this
- x 1438
Re: Whats this
I am not familiar with that engine, but it looks to me like a pcv (crank case ventilation) valve.
MikeT
- x 232
Re: Whats this
Single point injector.
- x 1438
Re: Whats this
A better suggestion than mine!
MikeT
- x 232
Oldpug
- x 93
Re: Whats this
Spot on Mike, It was a large unit with just one injector.
Most Peugeot people called it mono injection.
mixalis kal
- x 23
Re: Whats this
Left or right of this( I can't remember) there is a same case which is the air filter case...if it helps...except if it is sure that it is the injector...
Someone told me that the car has carburetor...but i doubt
Oldpug
- x 93
Re: Whats this
mixalis kal wrote: 17 Aug 2018, 13:03 Left or right of this( I can't remember) there is a same case which is the air filter case...if it helps...except if it is sure that it is the injector...
It is definitely an injector. Mono injected Peugeot`s were not around for long. As it was a single unit in the middle of the inlet manifold a lot of people thought it was a new type of carburetor.
mixalis kal
- x 23
Re: Whats this
Thank you very much!!! So I learnt that my car hasn't carburetor!!!
Also i would like to ask what oil does the manufacturer suggest...for TU3MC with engine code kdx.
Thank you again
Thank you again
Oldpug
- x 93
Re: Whats this
I think any 5w-40 semi synthetic will do the job.
