Lexia on Peugeot Partner?
cancunia
Unread post by cancunia »
I have a Berlingo and am thinking about buying a 2009 Partner. I have Lexia working fine but not installed PP2000 or Diagbox so wondered if in the short term that I can use Lexia until I get PP2000 or Diagbox running. I'm really just interested reading / clearing faults right now.
x 6950
Re: Lexia on Peugeot Partner?
Moved to Diagnostics Forum
It won't help - Lexia is for Citroen and really only good for older cars about 2007 and earlier - Lexia won't have the right architecture for Peugeot - which is why they are separate, despite sharing ECUs and similar components. They can have different electrical architectures and display the information differently on each vehicle.
You wouldn't have a problem if you can get Diagbox working - as that will solve all your issues as it contains encapsulated versions of Lexia and PP2000, as well as DIagbox for newer vehicles of all PSA marques, which it can launch automatically depending on vehicle.
cancunia
Thanks for the info, I'll see if I can find the Diagbox software again. I switched to Lexia from Diagbox as it was taking a fair while to load up & Lexia was all I needed for my '04 Berlingo.
