Lexia in east sussex
chris citro
- x 6
Can any one tell me who has a Lexia in east sussex as my daughter has a starting problem with her car .
- x 5672
Re: Lexia in east sussex
Chris, there is a list of Lexia owning members and a map here.
The map link is at the bottom.
PM them to arrange a session but be aware that some members don't log in regularly, you may have to try several.
chris citro
- x 6
Thank you I will pass that on to my daughter . I hope it will help to get her car sorted
OnlineHell Razor5543
- x 3296
It might be worth noting that Citronut had one ('lovingly' know as his DIS-Lexia!). I wonder if you still have it?
chris citro
- x 6
We don't still have it . We still have lots of his tools but not the one thing we need .
Fake Concern
- x 65
chris citro wrote: 16 Jul 2018, 21:00 Can any one tell me who has an Lexia in east sussex as my daughter has a starting problem with her car .
I have Lexia/Diagbox in Bexhill on Sea so I'm just down the road. PM me I'm happy to help.
chris citro
- x 6
Thank you I will let Claire know . And get back to you
Fake Concern
- x 65
PM and text message sent
Fake Concern
- x 65
Last Friday we plugged Claire's Synergie into my Lexia/Diagbox after a bit of faffing around to find the RPO number (I got it from Service Citroen) we looked at all the faults. However I have some questions;
It wouldn't show Diabox as an option, is that because of the age of the vehicle? (I find it easier to use than Lexia)
It showed the fault descriptions, but not the codes, why is that? Clicking on the fault just brought up the parameters they occured under and were all the same.
The Synergie FB group told Claire it was likely the engine speed sensor that was causing the problem (sounds likely to me as well) but she couldn't get an answer from anyone as to where it is located and if it's easy to get at either from the engine bay or laying on the ground as if so I'd have a go for her. I eventually found the sensor on Service.Citroen, but it doesn't really show the location. xud9te engine.
Some pics of Lexia to follow.....
- x 6945
Yes it will only run Lexia, due to the age of the vehicle.
What happens is there are a huge list of faults (often repeated) recorded on every occurrence on a historic basis.
I would make a note of each of the individual faults first, then try and clear these (after reading), then run the Global diagnostic to see what remains.
Fake Concern
- x 65
GiveMeABreak wrote: 09 Aug 2018, 23:08 Yes it will only run Lexia, due to the age of the vehicle.
Thanks for the reply
I have already done what you suggest as I took a photo of the faults, then tried to clear each fault, but afterwards it said some faults not cleared.
Why did it not give me fault codes?
Is the speed sensor easy to change/where is it located?
- x 6945
If the faults are permanent they won't go until they are rectified. Generally only intermittent or temporary faults can be cleared until they are re-triggered. Permanent ones can't be cleared if they are still there.
As for the speed sensor - If you don't have the VIN, I would need to know what engine this is first - this is the parts diagram for a 2.0 HDi 110 Engine - No. 6 on the diagram. But it will ofcourse be completely different for the 1.9D engine.
chris citro
- x 6
It is 1.9 d engine
- x 1490
Engine speed sensor on a 1.9TD is on the engine 'rear' flange, on the back side - it picks up the signal from the flywheel. It's brown IIRC and secured by a single 8 or 10mm hex bolt. Not that far up, above the inboard end of the OS driveshaft. You'd need it on ramps to get to it.
