20180707_153744 by Graeme McNulty, on FlickrI need to convert the new struts with small pipe connections to the larger 10mm pipe fixings for hydractive type.
Here's the hydractive pipe connectors:
20180707_153803 by Graeme McNulty, on FlickrAnd the new strut top with small pipes:
20180707_153815 by Graeme McNulty, on FlickrI've had a look at various old threads on here concerning the difference between the two. Some good info from Chris in Malaga but I'm keen to get an accurate set of info on the dimensions needed for the Hydractive pipe connection. I guess the inner bore is 10mm or a little more and the depth of the union bore can be measured but anyone know the size and thread pitch of the hydractive pipe union nut? It measures at about 15mm but not looked at the thread pitch - looks quite fine.
Any help greatly welcomed!
